3.4 cams
Old Nov 9, 2006 | 07:41 PM
Bubonic's Avatar
Default 3.4 cams
Why does the 3.4l "eat" its cams? This might be explained in the answer to the first question but is there anything you can do to prevent or slow down this process?
Old Nov 9, 2006 | 07:57 PM
SickSickSick's Avatar
Default RE: 3.4 cams
friction and heat. try running full synthetic oil. Sick
Old Nov 10, 2006 | 08:39 PM
The 3.4 uses flat lifters, and if you don't break in the cam and lifters properly, the cam won't last long. Also, as Sick mentioned, syntectic oil is the way to go after the initial break in.
Old Nov 13, 2006 | 01:22 AM
Bubonic's Avatar
so its the flat lifters that make the cam wear out faster?
bobc04
May 6, 2009 01:22 AM
94camarokid10
Jan 28, 2009 09:14 PM
FearThisInc
Oct 10, 2008 04:31 AM
Camaroslpss
LS Series Tech
10
Sep 17, 2007 06:43 PM
Camaroslpss
LS Series Tech
Jul 30, 2007 09:14 AM
