3.4-3.8 swap
Old 05-15-2011, 09:48 PM
seawolf8's Avatar
Default 3.4-3.8 swap
Does anyone know if you can swap out 3.4 with a 3.8 in a 94?
Old 05-15-2011, 09:57 PM
3800camaro's Avatar
Yes you can. You'll need the under dash wiring, engine wiring harness and PCM, tranny, fans, exhaust and a few other parts.
Old 05-15-2011, 10:58 PM
seawolf8's Avatar
Thank you. I am thinking about doing that type of swap.
Old 05-15-2011, 11:07 PM
Saint Ebony's Avatar
Third Generation Moderator
March 2010 ROTM
You'll also need pockets deeper than the Grand Canyon. Do yourself a favour and just buy a V8 car. It'll cost less.
Old 05-15-2011, 11:11 PM
Chaotic94's Avatar
September 2011 ROTM
^I agree. Or if you want to keep your car and get some serious power, do a 3500 top end swap and cam it. That's what I'm planning on doing. I've seen this done and the cars that it was done to were making 225-275RWHP with a tune. That's better than a stock z28.
Old 05-15-2011, 11:12 PM
Chaotic94's Avatar
September 2011 ROTM
Also, I might add, the top end swap will cost you less than $1000 with all the parts, gaskets, and the tune if you do the work yourself.
Old 05-15-2011, 11:49 PM
Adam9066's Avatar
if your going to go to a 3.8 you might as well just swap to a v8. other wise i would say just keep the 3.4
Old 05-15-2011, 11:52 PM
Adam9066's Avatar
dont you have to change out the pistons as well with swap. i know i looked into the 3400 top end conversion when i still had my 3.4 in the car and that you need to change the pistons to make it work other wise the compression is to high.
Old 05-16-2011, 02:14 AM
seawolf8's Avatar
Chaotic I never thought about doing a top end swap. Thanks for the idea.
Old 05-16-2011, 04:19 AM
Massey's Avatar
If you are going to go from a 3.4 to a 3.8, it is the same process as going from any V6 to a V8. You will need an entire doner car. Just buy a 3.8L car it will be far cheaper and chances are, unless you are a very skilled mechanic it will be more relaible as well.
Massey
Quick Reply: 3.4-3.8 swap
