2000 Camaro V6 gear ratios? help
Try this for the rear gear. Don't know about trans gears.
http://www.drivetrain.com/parts_cata...chevrolet.html
Mark.
Mark.
Depends on your RPO codes... Why don't you just do some research on the web?????
You will either have GU5 or GU6. GU5 is 3.23 gear ratio, and GU6 is 3.42.
Also look for G80, which is a Limited Slip Differential..
And post back with all RPO codes beginning with M... should only be 2 I think.
