1997 V6 Sound System - Where's the amp?
Old Apr 8, 2010 | 04:27 PM
MikeMJ Fife's Avatar
Default 1997 V6 Sound System - Where's the amp?
Hi guys, I'm new to the forum although I've had 3 F-bodies from 1999 until now even although I live in Scotland! My latest is a 1997 Camaro which is almost perfect - except for the sound system which is playing me up. It has an aftermarket deck (Ripspeed) with an inbuilt amp, but I think there's a factory fitted amp somewhere in the car - isn't there? If there is I need to reach it to check the speaker wiring (r/h front speaker is dead).
Old Apr 8, 2010 | 04:48 PM
evilkal's Avatar
It's in the headunit itself I would think?
Old Apr 8, 2010 | 04:52 PM
luciora's Avatar
Is it a monsoon system?
Old Apr 8, 2010 | 05:20 PM
Don't know if it's a Monsoon that was originally in the car. I suspect the replacement unit (with amp) has been wired through the original amp wherever that is?
Old Apr 9, 2010 | 02:08 AM
luciora's Avatar
If it is a monsoon system in your car then there will be an amp. I believe its behind the driver seat below the speaker in next to the rear driver side seat. If its not a monsoon system there won't be an amp.
Old Apr 9, 2010 | 04:54 AM
Thanks, I'll check that location out.
Old Apr 9, 2010 | 06:46 AM
Yep! found a Delco monsoon amp (model 16218081) in front of the spare wheel. All I need now is my motor electrician to come and check it out.
Next job, I need to take the passenger door panel off as it has after market Pioneer speakers that are too big to unscrew through the speaker cover.
Any hints on how easy / difficult it is to take the door panel off guys?
Old Apr 9, 2010 | 11:03 AM
luciora's Avatar
It's quite easy just be careful when pulling it off not to crack the panel. I have a friend ( eric ) that has an '00 and he cracked the door panel pulling it off.
Old Apr 9, 2010 | 11:17 AM
OK thanks -I'll take it slow.
Old Apr 9, 2010 | 11:52 AM
luciora's Avatar
Yupp, let us know how it turns out.
DarkrhaveN
Apr 15, 2010 04:58 AM
klong2194
Jan 28, 2010 02:04 PM
Crunchy
Nov 22, 2008 01:47 PM
1980rscamaro619
Jan 11, 2008 10:20 AM
leech91
Mar 5, 2006 08:27 PM
