1997 3.8l 5spd driveshaft swap?
Old Nov 16, 2006 | 03:13 AM
Minerman8929's Avatar
Default 1997 3.8l 5spd driveshaft swap?
I want to shed the original two piece drive shaft in my 1997 3.8l 5spd. i might be able to get one from a 1993 pontiac firebird t/a with a ls1. any one know if i can do a direct swap from a two piece to a single drive shaft and which one will fit my 5spd. i hate carrier bearings and two piece drive shafts all together. stupid design if you ask me.
Old Nov 17, 2006 | 12:51 AM
v8chvyguy's Avatar
Default RE: 1997 3.8l 5spd driveshaft swap?
We just built a one piece shaft for a firebird today. Thats the best way to go. We reuse the origional tube yokes and fab a one piece shaft. Cut the carrier mounts off the torque arm if needed and it bolts right in.
Old Nov 17, 2006 | 07:52 PM
was yours a 3.8l w/. 5spd, if so i would like to know the total length center of u-joint to u-joint. i would appreciate it if you had the demensions. it would save me time measuring from trans to diff. did you make it a slip yoke design or a straight tube.
ssoper89
LS Series Tech
18
Feb 4, 2011 07:06 PM
fasfzr1
Aug 12, 2010 08:04 AM
Dave81Z
Sep 21, 2009 11:23 AM
monkeystomach
Oct 24, 2007 10:25 PM
cas099
Nov 21, 2006 01:10 PM
