1996 3.4l engine light, sputtering/backfire on acceleration
Chaotic, there are just 2 coolant temp sensors. The one at the very front of the driver's side cylinder head (for the instrument cluster gauge only) and the one next to the thermostat housing. This second one sends info to the powertrain computer which uses it to handle fuel injection, cooling fan, and transmission functions. The only other temp sensor is the intake air temp one fitted to the duct ahead of the throttle body. Well, there is the transmission fluid temp sensor (94 and up) but that is inside the transmission pan.
that should be the correct one for coolant temp. you also should have an air temp sensor on the air intake that the computer uses. have your coils tested. a bad coil will do weird things. you have a obd1 ecu with a obd2 plugin. you can make a adapter for a obd1 scanner that will work on the 95. not the 94 though. lol. http://shbox.com/1/xraycable.jpg
