1995 3.4L will not start
Old Oct 22, 2012 | 07:25 PM
alvaradoguy2002's Avatar
Default 1995 3.4L will not start
I have a 1970 opel GT that I have put a 3.4l from a 1995 camaro.When I try to start it, it will start right up and then die. When I try to start it again. It backfires but will not start. I suspect the crank sensor. I pulled the codes and got a code 36 which relates to the crank sensor. Any suggestions?
Old Oct 26, 2012 | 10:00 PM
66fordman's Avatar
Crank sensor seems to be the first place to check! Check wires and connectors.
Old Oct 26, 2012 | 10:10 PM
wayne242's Avatar
"When a crankshaft sensor has failed or is failing, certain timing problems will arise in engine function. The engine may start normally in some cases, but will cut off after a few minutes (or seconds) of operation. More than likely the engine will be unable to start at all. Since the crankshaft sensor is responsible for engine timing, the driver may experience engine backfire or irregular rpm function, if the vehicle starts at all."
Hint the backfiring due to timing.
Old Oct 26, 2012 | 10:12 PM
wayne242's Avatar
Bad wires wont cause the symptoms he described. Clearly a issue with timing, which the crank sensor is directly tied to.
Old Oct 27, 2012 | 09:31 AM
66fordman's Avatar
I should have clarified, I ment the wires that go to the sensor.I have seen codes kicked due to a chaffed wire leading to a sensor.
Old Oct 29, 2012 | 08:32 PM
Kipp88's Avatar
this is true^
also if you keep the car outside, you never know what kind of critters might get in and chew wires too. i bought a lumina a long time ago that ran like junk and always threw a MAP code. followed the wires and found 2 chewed wires near the computer that turned out to be the ground and a signal wire for the sensor.
kingmoon2142
Jul 2, 2014 04:28 PM
Camaroforlife
Jan 15, 2013 05:29 PM
SS Delux
Dec 18, 2012 06:56 PM
alvaradoguy2002
Jan 15, 2012 08:30 PM
millercas2003
Aug 19, 2010 10:59 PM
