1994 v6 3.4l
1994 v6 3.4l
Hello . I need some help please. My 94 camaro v6 seems to have been damaged,timing ,head gasket, etc. What vehicles does the 3.4l come in besides the camaro/firebird? If I swap another 3.4l for a 3.4l do I need to change the pcm,bcm along with it? If I redo the timing chain in original I should do the cks 24x as well since balancer is already off. If I change a different pcm from another camaro along with the steering column I need to change the airbag module and bcm( due to different key) also. I can't seem to get the airbag light to go out and also the camaro will not start anymore.
There is spark fuel but now not even back firing. I have had this write off vehicle for almost 8 years(my white elephant) and I am going crazy trying to get it road worthy for inspection.
Please Help. Don
Please Help. Don
