1994 Service Manual torque specs
Does anyone on the forum have the GM service manual for a 94 Camaro? I'm in the middle of a complete overhaul of the 3.4 and need the torque specs for the head bolts, intake manifold bolts, etc. IIRC the engine section of a GM manual has those specs in a list at the back of the section. Torque sequence is also important.
I thought I could use the info off the alldataonline subscription that a local service station has. I've already found info on that system to be wrong and I don't trust any of it now. For the torque spec section alldata provides a service bulletin that describes head bolt replacement and a revised torquing sequence. The problem is that the bulletin applies only to the 3.4 VIN E engine (which has aluminum heads) that is used in the FWD applications.
