1994 camaro charging system not working
Old 06-08-2015, 06:07 PM
clinebarger's Avatar
Is this a 194 socket and bulb with alligator clips on each end of the socket leads and unplug the alt and jumper in the bulb?
Or is this test bulb an inserted light - unplug the alt, plug in the test light to alt harness plug and plug test bulb into alt receptacle?
Here is a pic of my test harness, I unplug the Regulator & plug my harness in & jump it to the hot post on the back of the Alternator.
Originally Posted by cam69
yes so I gues the other alt I had was probably ok.lol Oh well at least its working.
Thanks again...
Glad you got it fixed!
Technically you have the wrong Voltage Regulator, A '94 Camaro Alternator should charge with just the L terminal hooked up.
It is not professional or correct for them to tell you to modify your Stock harness for an Alternator to charge, Just my opinion on the matter.
Attached Thumbnails 1994 camaro charging system not working-alt-001.jpg   1994 camaro charging system not working-alt-013.jpg
  #32
Old 06-08-2015, 06:17 PM
cam69's Avatar
I agree with you.I bought this from a alternator starter rebuild shop in Los Angeles(,CP alt and starters)for 41.00 figured since I was down in L A anyways.It has a one year waranty.I guess I should have went to Autozone and bought one,but they wanted 130.0 for the same delco remey brand alt.
Im just glad its working..Thanks again for all the help and info..
  #33
Old 06-08-2015, 06:55 PM
I agree with you.I bought this from a alternator starter rebuild shop in Los Angeles(,CP alt starters)for 41.00 figured since I was down in L A anyways.It has a one year waranty.I guess I should have went to Autozone and bought one,but they wanted 130.0 for the same delco remey brand alt.
One from Autozone could be wrong too!!! They try to consolidate too many part numbers into one part number. AC-Delco probably has 10 different Alternator P/N's to their 1, That is how this crap happens in the first place.
  #34
Old 06-08-2015, 07:08 PM
cam69's Avatar
Understandable, It seems like there are so many variations through the years,but for now im just keeping it this way.At least for the duration.So far so good,Its been working ok.I hope it last.
Joe1969SS
09-30-2010 06:18 PM
TheKingofLeon
07-05-2009 04:46 PM
kaine
05-08-2009 01:52 AM
got3ofem
02-07-2008 04:37 PM
Quick Reply: 1994 camaro charging system not working
