will a 95 z28 rearend work in a 98 z28?
for a while now, the rearend in my 98 z has had some nasty noises coming from it. i thought about having it serviced, but then i found a rear end from a 95 z28 for very cheap. it is a good rear end and looks like it will bolt right in. both rearends have traction control. should i go ahead and make the swap, or should i have my current rearend serviced, this is a stock ls1 and i have no plans to up-grade the power.
booghie
LS Series Tech
Mar 31, 2010 09:03 PM
