Transmission Problem?
Old Dec 5, 2013 | 03:43 PM
Xiantyl's Avatar
Default Transmission Problem?
Whenever I drive my car and i give it enough throttle to shift at 2k rpm , it makes sort of a whine towards the rear right side of the car, if i floor it it doesnt make the noise? Could this be the differential maybe? its not coming from the middle .
Old Dec 5, 2013 | 04:05 PM
sounds like a axle bearing, check fluid level in the rear
Old Dec 6, 2013 | 12:19 AM
Xiantyl's Avatar
How would i go about checking the level if its all bolted on lol
Old Dec 6, 2013 | 01:38 AM
theres a plug on the side of the center section, about a third of the way up. with the car level, the oil level in the rearend should be up to the bottom of that hole, just under is ok.
Eddie Cotter
Oct 11, 2014 09:43 AM
BoricuaHec01
Oct 30, 2010 01:09 PM
aktham
LS Series Tech
May 5, 2009 01:40 PM
harvick boy
82-92 V6 Tech
May 21, 2007 08:03 PM
SomeCallMeFonzi
Dec 14, 2006 04:41 AM
