tranny question
Old May 11, 2011 | 08:40 PM
1997 rs camaro's Avatar
Default tranny question
Ok I have a couple of manual transmission ?'s. One- if you are driving and your rpm is less than 2000 and you try to accelerate there is a odd noise coming from the tranny, and when you get above 2000 it goes away for the most part, it might still be there a little but not much at all. And I know if you want to accelerate I should just down shift, but I am wondering if it would be anything to worry about, or what could it possibly be.
Two- I was told it was a shifting solenoid but what do you think. when shifting from 4th to 5th if you are not around 2000 rpm it grinds, and when putting it into rev. it grinds a little too. 1st thur 4th are perfect. what do you guys think.
Old May 12, 2011 | 10:56 AM
There are no shift solenoids in manual transmissions. The grinding is probably due to bad synchros, or the clutch not releasing fully.
shorkey
Jun 12, 2009 08:33 AM
terrychamp01
Sep 20, 2008 01:28 AM
89rscamaro
82-92 V6 Tech
Sep 7, 2007 01:39 AM
Jimbo
Jan 13, 2007 12:47 AM
kjz
Jun 17, 2006 03:33 AM
