T-5 compatability
Old Jan 4, 2011 | 07:03 PM
MelloYello's Avatar
Default T-5 compatability
ive tried looking on google, but its hard to find my specifics.. and i dont have much experience, if any at all, dealing with borg-warners..
my question is, how universal is the T-5 trans? my friend has one to sell out of a fox body mustang.. it dosent have the bell housing .. it accepts a mechanical operated throwout bearing. thats all i know about it. is it able to match up to a gen 1/LT1 chevy engine small block? i know an aftermarket bell housing will, but do the input shaft lengths,type of throwout (hydraulic vs mechanical), and splines differ from T-5 to T-5?
Old Jan 4, 2011 | 07:52 PM
If you mean a 70's LT1 the t5 can not handle the torque. The other question would be what are you putting it into. You use a bell housing from a camaro you will need a transmission from a camaro. The Camaro bell housing rotates the transmission 15 degs. It think there was some very early mechanical clutch T5 but they have been around so long they there are a few different types of clutch engagement systems even within Chevy. I imagine Ford has many more. Even 4th gens 3.4 and 3.8s are different.
Old Jan 5, 2011 | 03:58 PM
MelloYello's Avatar
yes it would be my 4rth gen.. its a pretty custom job im doing to it..
maybe i should look around for a T56 just to make it a lil easier
Old Jan 5, 2011 | 03:59 PM
MelloYello's Avatar
T56 from a previous camaro, that is
Old Jan 10, 2011 | 07:05 AM
hoursetraitor's Avatar
the t5 is weird the mustang one isnt even close to the one in the 3rd gens, i know ive owned several foxes and 3rd gens. differant spline counts differant bell pattern. theres a gm t5 and a ford t5, on the later s10 t5s the switched to a ford style t5 but with a 26 spline from the 14. so anyways a 3rd gen t5 bellhousing will not bolt to a mustang t5.theres no factory way to use a fox t5. and they are weak. ive went thru a few on my 5.0s too much torque
Old Jan 10, 2011 | 07:07 AM
86-93 mustangs use a cable clutch, but they haVE THE FORD PATTERN. anyways no godifferant spline count no bellhousing
!WildChild!
Sep 17, 2011 06:28 PM
resurrect
Mar 13, 2011 11:09 PM
Massey
Aug 1, 2010 08:08 PM
ramsey041587
Feb 8, 2009 06:28 PM
80RSchik
May 18, 2006 11:25 PM
