Reverse Grinding
Hi guys i just bought a used 94 v6 camaro with 184000 miles its a manual and the reverse grinds and pops out of gear if gassed to hard. If i start the car in reverse its a bit better as far as not grinding but it will start to slightly. Also if i just light do gas to back up it still grinds lightly but not as hard. In order to back up i have to basically go very slow or it will grind and force it out of gear into neutral. Has anyone had this problem or know what this could be?? Ive been told maybe the clutch or reverse synchronizers so if anyone could help me please? and thank you
look for another trans and see what you can find that will work. gears are goin or something is bent. you may be able to find a good used trans for less than a rebuild will cost
Alright so you believe its a trans issue?
I suggest changing the reverse selection before condemning the trans.
As engine is running, push in clutch pedal and select fourth gear, to stop the gears from turning, then select reverse. Most trans, reverse is not synchronized. But, you must ensure when clutch is disengaged, nothing is turning in trans. If clutch is dragging ever so slightly, reverse will be hard to engage. |
yep, if you are able to work on a trans then yes do the work
ok this may seem like a dumb question but what type of transmission is in the v6 94 camaro manual bc im trying to find used ones
It is a T5, I think if needs to be a 4th gen camaro T5.
Reverse is a non- sync'ed gear the first thing people notice what the pressure plate is failing is that rev grinds. 99% of the time when a customer shows up complaining about reverse grinding it is because the clutch is not fully disengaging. Think of it this way if you start the car with the clutch in (it should not start any other way) and you try to put it into reverse and it grinds, what is grinding? The clutch has been pushed NOTHING in the trans should be turning if the clutch is doing its job. Poping out of gear is another story. How long has it been grinding? You may have waited too long or if you have to push to hard you may have bent the shift fork. Before you ask, the forward gear are synchronized. As long as the cluch is still partially disengaging the forward gear will not grind they will just require a little hard push. |
Ok thanks and i made a big mistake and bought it without checking the reverse gear out assuming it worked fine bc all the forward gears did so i dont know how long its been grinding for sure. but it still lets me reverse a small bit then grinds. like it wont let me get to the point where my foot is off the clutch and completely on the gas or itll grind really hard
Originally Posted by Mack40
(Post 665445)
the way i read it, even holding hard its popping out of gear and grinding. gona have to take the trans out and have a look inside, im thinking at the least replace reverse gear and like gorn is saying you should replace the clutch and pressure plate.
