replacing fly wheel or flex plate - Removing trans
Old Mar 18, 2012 | 02:45 PM
borjawil's Avatar
Default Trans rear seal question
94 z28 5.7l LT1 not sure what trans but its an auto.I removed the drive shaft thinking I need to move the trans back and change the flex plate but turns out the starter was is the issue. So I have to replace that. When I removed the drive shaft I knew some fluid would come out but not a whole lot.
Seems quite a bit came out. Would that mean my rear seal is bad?
Last edited by borjawil; Mar 18, 2012 at 04:26 PM. Reason: dont need help with this issue any more
Old Mar 18, 2012 | 11:33 PM
No, it means you took the driveshaft out and now there is nothing to keep the fluid from coming out.
Murda99v6
Aug 2, 2010 06:05 PM
80ZJoe
70-81 V8 Tech
13
Feb 3, 2010 10:37 AM
wiborja
Dec 18, 2009 05:36 PM
Saint_Ali
Nov 27, 2008 09:22 PM
molamann
Sep 6, 2006 06:38 PM
