Trans rear seal question
94 z28 5.7l LT1 not sure what trans but its an auto.I removed the drive shaft thinking I need to move the trans back and change the flex plate but turns out the starter was is the issue. So I have to replace that. When I removed the drive shaft I knew some fluid would come out but not a whole lot.
Seems quite a bit came out. Would that mean my rear seal is bad? |
No, it means you took the driveshaft out and now there is nothing to keep the fluid from coming out.
