No 2-4th gear 4l60e 97z28
Old Aug 2, 2014 | 11:41 PM
Poolio's Avatar
Default No 2-4th gear 4l60e 97z28
Can I pull the 2-4 servo without dropping the tranny? I replaced the 1-2 servo today because I got a servo code. The old one ohm'd out at 26 the 2-3 ohm'd out good as well. Have reverse, just no second or o/d. I know it could be the band but for the money I'd rather try the servo first. Any suggestions? Also is it bad to drive the car this way?
Old Aug 7, 2014 | 08:23 PM
Socom's Avatar
November 2010 ROTM
October 2011 ROTM
Hows your fluid look? Sounds like the 2-4 clutch is burned up. Does it go into second when manually shifted?
Thomas Wood
May 1, 2012 02:17 PM
3.4putter
Jan 28, 2012 07:35 PM
2000
May 3, 2011 12:34 PM
2000
May 3, 2011 12:19 PM
sewerrat
82-92 V8 Tech
Jul 23, 2005 07:24 AM
