Need something cleared up
Old Mar 17, 2013 | 05:18 PM
CMURDAx's Avatar
I skimmed over that part before. So a previous owner then converted your car over to an automatic? Could have slapped in one that was already on it's last leg. Also, not hooking up anything to make the torque converter lockup can burn up the trans. The internal fluid pressure is designed to flow a certain way once the t.c. locks up. Take a look see if there is anything plugged into the lockup solenoid connection on the side of the trans. Sounds like a shlock "shadetree mechanic" may have been putting his hands where they didn't belong.
That was my thoughts also, but if it was manual before he did something right as far as ripping everything pertaning to it being a manual out, so I feel like the vin decoder was wrong. Im calling a trans shop around me tomorrow to see if they can take a look at it for me
Old Mar 17, 2013 | 06:17 PM
Could be a goof with the decoder. Get under the car and look up at the trans tunnel and see if there are any signs of it having had an opening for the shifter. No trace, no manual trans.
