HELP!!! please transmission help
Old Feb 18, 2012 | 05:37 PM
Chevy-Man-86's Avatar
Default HELP!!! please transmission help
transmission is finally going out on my 2000 ss maro all i have is 1st an 2nd gear the other 2 gears slip completely and wont catch anymore.....it would greatly be appreciated if i could find a new 4l60e, new transmission i would like to know the best one i could get for an everyday driver but upgraded nicely
Old Feb 18, 2012 | 07:57 PM
torque_is_good's Avatar
get yours rebuilt but just ask for
upgraded servo, sprags, clutches, sunshell
Old Feb 21, 2012 | 08:49 PM
priced the rebuild its 1250.... hes gonna put in upgraded discs new sunshell and a shift kit....... 1250 isnt bad but do you know if i could get a tci or b&m new for around that price?
Old Feb 21, 2012 | 11:13 PM
performabuilt is a site sponsor. they have a good trans and converter. trans is 16 1700 then add converter. i would recomend level one minimum.
http://shop.performabuilt.com/LEVEL-...60EL1LT1NC.htm
heres another place thats got some interestin stuff. i would recomend level 2 minimum.
4L60E Performance Transmissions from PATC
Old Feb 22, 2012 | 07:59 PM
does that include remove and repair and a reman'd torque converter? If not, I can get that done as a bench build for about $800, maybe a tad less. A stock reman'd tc is under $100
basically a stock rebuild with upgraded clutches and "the beast" sunshell is what you're getting.
If it includes removal, re-installation and the 12 quarts of tranny fluid then that is a good deal
Either way, slap in a new rear main seal while the tranny is out and a new tranny mount
seriously, replace the rear main seal. You're already there and the part is cheap.
Old Feb 22, 2012 | 10:29 PM
no lol thats with me taking it out an bringing it to him and i already have extra fluid because i thought it was slipping because the filter possibly so replaced it an bought an extra jug of fluid......also i had boughten a new torque converter in september so its still good....rear main seal lol yes definately i need to do it its been leaking.....just really eerie about taking my car to a shop its my baby the last time i did they f*cked it all up i took it in for simple flex plate change because the bolts came lose an didnt have time to do it myself........needles to say i get it back an theres vibration slowly getting worse they didnt tighten the top bell housing bolt or the torque converter bolts so 2 of them snapped of in it an one backed out.... they also broke my oil sensor...now how the F*** do you do a job easy job like that especially being ase certified????? i took everything apart did it myself an drilled new holes in my flexplate.... no vibration an no problems tranny jus needs rebuild cuz of miles (
Inked88
Jul 27, 2011 10:57 AM
dsinclair999
Feb 21, 2011 11:24 AM
randolphdelpriore
Jul 4, 2008 11:05 PM
DeputyDog
May 22, 2008 02:45 PM
camaro girl
Apr 8, 2007 04:58 PM
