HELP!!! Clutch Crap
Old Apr 16, 2012 | 02:22 PM
BURN IT's Avatar
Default HELP!!! Clutch Crap
When my car is running it wont go into gear. it just grinds. i put on a brand new master and slave cylinder and those work just fine. Am i going to have to take the transmission off or is there an easier way to fix this?
Old Apr 16, 2012 | 03:22 PM
greenarrow's Avatar
September 2009 ROTM
It helps to know what car and engine/tranny combo. But either way it sounds like you're tranny needs some work.
Old Apr 17, 2012 | 05:04 PM
BURN IT's Avatar
Default Driveshaft Removale! Help!
its a 93 camaro 6 cylinder 3.4... is there some kind of trick to get the driveshaft off? i took the u bolts off and it just wont budge. i tried prying it apart with a crow bar but im getting no movement.
Old Apr 18, 2012 | 01:03 PM
greenarrow's Avatar
September 2009 ROTM
Did you use some penetrating lube on it. Try beating it around a little with a rubber malet? Once you get it off, would probably get a good idea to repalce the U joint.
Old May 2, 2012 | 02:13 PM
BURN IT's Avatar
so i still cant get into gear. i took the clutch out and it seems fine. used with some burn marks but can that be the reason i cant get into gear? my slave cylinder is pushing the fork just fine. brand new master cylinder too. im kind of scared that my transmission may be broke. if so, is it something i can fix myself?
Old May 2, 2012 | 06:34 PM
Are you sure the the pressure plate is disengaging? follow the logic. For grinding to happen something must be turning. The job of the clutch is to stop the input shaft from turning. SO it is not possible to have a fully functioning clutch and a grinding noise. Either your hydralic system is not pushing far enough, or pressure plate is gone or your clutch plate is warped. If you SURE your hydralic system is working then install a clutch kit and all will be well.
BasicConcepts
Aug 24, 2010 10:52 AM
luvmysccamaro
Oct 9, 2008 02:43 PM
94Ztwo8
Nov 8, 2006 07:52 PM
