help clutch acting werid
Old Jul 11, 2012 | 09:24 AM
dogdog130's Avatar
Default help clutch acting werid
well i was driving it today and noticed if i dont touch the clutch in neutral it sequels but if i barely touch the clutch it stops im thinking it needs adjustment but i dont think you can on a 95 clutch replaces 10K ago
Old Jul 11, 2012 | 09:57 AM
Throw out bearing, most likely is the culprit.
Old Jul 11, 2012 | 10:10 AM
dogdog130's Avatar
even if it just bearly thoughted it stops
Old Jul 11, 2012 | 12:38 PM
To me it sounds like the bearing may be running dry and when you apply pressure to the pedal you are forcing the bearings to rotate rather than slide. If this is the case, it eventually start making noise also when you press on the pedal.
Old Jul 11, 2012 | 12:58 PM
But the "with pedal pressure" noise would have a different sound to it, sorta like when Pete is tooling around on his steel wheeled roller skates. Throwing sparks is optional.
Old Jul 11, 2012 | 03:52 PM
dogdog130's Avatar
im trying to fix it so i can sell it for 700$
Old Jul 11, 2012 | 04:21 PM
Mikey.'s Avatar
For 700$ let the next owner worry about it imo.
Old Jul 11, 2012 | 07:53 PM
dogdog130's Avatar
well i have had it for sale for 3 days it has 277K on it
Dirk88
Aug 31, 2012 03:43 PM
97z28slp
Jul 24, 2011 08:31 PM
xxRONNIExx
Jun 23, 2009 04:03 PM
red star
Jan 9, 2009 02:40 AM
94 z28
Apr 23, 2008 02:45 PM
