Fluid leaking need to know what the name of this part is
Old Nov 30, 2014 | 04:01 PM
blakeyon2asd's Avatar
Default Fluid leaking need to know what the name of this part is
Hi everyone I've got a 95 3.4 automatic and just noticed that it's leaking transmission fluid. I have found where the leak is coming from but I don't know what the name of the piece is that needs to be replaced. The fluid is coming from behind the piece and seeping through, it's leaking when parked after a drive. It's the bright cylindrical piece with the wires going into it. Any help would be greatly appreciated. Name:  unnamed.jpg
Old Nov 30, 2014 | 06:23 PM
That's the vehicle speed sensor (VSS). Even though the pic says Z28, the transmission is basically the same.
Old Nov 30, 2014 | 07:33 PM
Thank you! I saw those when i pulled the partd diagram for the transmission but i couldn't tell what it was.
Buck Thompson
Mar 14, 2015 06:37 PM
Brian Z.
Dec 15, 2014 08:53 AM
Cammy 3.8lV6
Jul 6, 2010 11:01 PM
BobbyX
70-81 V8 Tech
Nov 15, 2007 01:58 PM
