Floorboard vibration at high rpm @ 5000
Old Aug 14, 2025 | 09:04 AM
Wsg's Avatar
Wsg
Default Floorboard vibration at high rpm @ 5000
Hello all , new to forum and have a question . 1997 z28 with 177000 miles on it , at full throttle approaching 5000 rpm I get bad vibrations from floorboard. Engine and tranny otherwise run fine . Is this a bad driveline or something else? Only repair shop in my little southern city leaves a lot to be desired. Thanks for any help or suggestions .
Old Aug 14, 2025 | 01:36 PM
is it doing it in all gears including neutral?
Old Aug 14, 2025 | 03:20 PM
Wsg's Avatar
Wsg
happens from tranny being placed in drive ( { o/d } and full throttle in in first or second gear . Haven’t held pedal down until high rpm in third or overdrive { 4th } . I’m not sure if it’s driveline or something else. It’s smooth until it’s not , it’s a bad vibration . Only happens as it’s at redline before tranny up shifts . Thanks for your reply , I’m not even close to being a wrench .
Old Aug 14, 2025 | 09:09 PM
do you know if you have a two piece driveshaft? has the transmission mount been replaced with poly mount?
Old Aug 15, 2025 | 07:38 AM
Wsg's Avatar
Wsg
out of town at this time , check when I return.
pepe
Feb 24, 2020 04:33 PM
1974z28
21
Feb 13, 2019 05:51 PM
IMDATMONSTAZ28
Aug 16, 2010 03:11 PM
wsmikey
Apr 7, 2010 08:11 PM
amers041
Jul 9, 2005 12:49 AM
