first gear slipping
first gear slipping
I have a 1995 Camaro z28 with an auto trans and my first gear is slipping. IfI get on it too hard it will stall from shifting from 1st into 2nd. So I figured it was just a sticky valve and I had just bought the car so I just thought the guy had not changed the fluid in a while so I added lucas's trans additive thinking it would solve the problem and it didn't. Andactually the fluid looked a little burnt.So I ruled out the idea that it has a sticky valve. I'm gonna take it todo some tranny diagnostics and try to see what the problem is. What do you guys think it is? Has this happend to you?
-Nick
-Nick
RE: first gear slipping
Your transmission is broken, and needs trbuilding.
Possible causes:
Forward clutch assembly or accumulator
Input housing and shaft seal
1-2 accumulator valve stuck or damaged
Low roller clutch damaged or worn
Torque converter stator roller clutchnot holding
1-2 accumulator assembly bad
bad line pressure
Possible causes:
bad line pressure
