97 z28 a4
Old Jun 16, 2014 | 04:51 PM
Poolio's Avatar
Default 97 z28 a4
Got a new transmission, shipped dry new. Put in a 3000 stahl revmax converter. Ran fine for a few months, now it's holding first too long. Checked the tps. Voltage all checked out. Have the 5 volts, solid ground, no rapid jumping in voltage when opening throttle. Any ideas? 1-2 solenoid? Vss, accumulator spring? Any help would be appreciated
Old Jun 16, 2014 | 09:35 PM
Socom's Avatar
November 2010 ROTM
October 2011 ROTM
Check your trans fluid and make sure its ok
Old Jun 16, 2014 | 10:19 PM
Poolio's Avatar
I'm gonna drop the pan, replace the fluid and filter and change the solenoids. They're pretty cheap. I also read the 1-2 one has a spring in it and hit it with some wd/40. I'll probably check out the accumulator while I'm in there. Just weird how it ran perfect for months now just started doing this. I know o/d is working because I'm at 3000rpm at 90 and that's right on with 3:23. Thanks for the advice. I hope it's that simple. The last one I lost drive and overdrive, I just bought a new tranny. It had like 120k on it. I figured new motor might as well buy a new tranny
