97 Camaro z28 slave cylinder?
hey guys awesome site just joined. I have a 97 camaro z28, 6 speed m/t. I just replaced the clutch with a zoom HP grabs and goes. My problem now is that i have very little clutch movement, like it grabs the second i let it out then thats is theres no pedal? i tryed bleeding it no go. Is it time for a slave cylinder or new clutch master cylinder? thanks guys any help is apperciated.
I have a similar, if not exact, problem. My clutch engages and disengages at the very slightest of engagement and disengagement. I have to push in my pedal maybe an inch for the clutch to disengage and same with release. The rest of the travel is just play. My clutch isn't slipping at all but it is the same clutch since I'VE owned the car which has been since roughly 125k miles. Its at 150,150 now. No info on if the clutch has ever been replaced but again, there is no slip at all. If car is stopped & in 3rd gear, the engine will die if I try to engage clutch. (That is a viable clutch slip test, right?)
I'm just not sure if I have a clutch replacement on my hands or a clutch master cylinder replacement.
