1995 4l60e
Old Apr 16, 2014 | 08:08 PM
Ted Von Kampen's Avatar
Question 1995 4l60e
I have been rebuilding a 1995 LT1 with auto transmission. Among a number of things, I have used a BG transmission cleaner and then changed filter and flushed entire system. Before this procedure, the transmission shifted really hard from first to second and then the other shifts were softer, smoother and normal in my book. It does not see to slip, just takes it a while to do the shift at about 2000 rpm. When I say hard shift, it tends to grap and jerk you a bit. Looking for things to check and possible causes to remedy.
Thanks in advance
Old Apr 17, 2014 | 12:54 PM
Socom's Avatar
November 2010 ROTM
October 2011 ROTM
Check your fluid level, low fluid can make it shift late and harder.
Old Apr 17, 2014 | 03:37 PM
Hopefully you were careful not to leave any foreign material, like tiny bits of fabric from cleaning rags, as they can foul up the valve body and give all sorts of weird problems. Otherwise you may have some bad parts: like a 2-4 band apply servo, the "A" solenoid sticking, piston seal nicked worn or burred in the 1-2 accumulator.
Old Sep 27, 2014 | 10:02 PM
VALHAR's Avatar
A bad TPS or a PCU can cause these problems.
Old Sep 28, 2014 | 06:08 AM
check grounds, check vss connection and wires. look for any wires that may have gotten squished.
Old Oct 4, 2014 | 12:42 PM
95 camaro 406's Avatar
did you rebuild or just flush it ,pictures I hear alot is what helps others post some pics of your build
ThisGuy68
Mar 15, 2015 01:02 AM
My96RS
Oct 3, 2011 11:06 PM
Lawhead09
Feb 15, 2010 02:23 PM
3800cc
Jun 7, 2007 03:46 PM
