Wheel Spacers Require Lug Nut Cut
Old Jan 12, 2018 | 04:48 PM
Ninety4z28's Avatar
Default Wheel Spacers Require Lug Nut Cut
Hey guys thinking of getting 15mm wheel spacers, just wondering if i need to cut the stock lugs. Please let me know, thanks!
Old Jan 12, 2018 | 07:56 PM
Y2K's Avatar
Y2K
I don't know the answer but I went with 22mm hub concentric adapters , pressed out the adapter studs to make them spacers and used longer ARP lug studs. I can get you the part numbers if you want.
I'm running 315/30-18's on the back of my '01.
I have 275/35-18's on the front,thinking I'll space them out too as they rub if I turn real sharp,car is lowered 1 1/2".
Old Jan 14, 2018 | 05:05 PM
Ninety4z28's Avatar
Wow thank you! I appreciate your response, i just ordered up 1/2" spacers, I'm running 285/35/18 in the rear and 245/40/18 in the front, with 9.5 all around. Hoping the spacers will make the rear look a little more aggressive!
bd92rs
Feb 23, 2011 01:51 PM
Slayer
Jun 27, 2007 01:59 PM
jhop16
Jan 23, 2007 08:11 PM
thedvsone21
Mar 29, 2006 12:04 AM
