Sway Endlink Bolt Sheered Off
Old Apr 4, 2014 | 04:58 PM
libertyforall1776's Avatar
Well GM SI says nothing about alignment of the rear stabilizer shaft links, so I am trying to find out if they need to be perpendicular with the ground/control arms?
Old May 10, 2014 | 11:45 PM
VALHAR's Avatar
NO LOWER THAN A GRADE 8 OR 10.9 METRIC AND ROLLED THREADS.
OR GO TO YOUR LOCAL AVIATION SHOP AND GET A AVIATION GRADE NUTS AND BOLTS, BRING YOUR OLD ONE'S OR GO TO "ARP" AND FIND SOME THAT WILL FIT.
On my old TA even with grade 8 and larger bolts and nuts they still failed. So I put grade 9 bolts on and no more failures again. And get one of these.
Robot Check Robot Check
Old May 29, 2014 | 09:54 PM
Wow, I noticed the driver side rear just sheered off, just the same as the other side. *rolls eyes*...
Old Jun 2, 2014 | 11:11 PM
Prothane/Dee Engineering says they use Grade 5 bolts. By contrast Hellwig's rear bolts (which private labels Strano's sway bars) are Grade 5 too, but apparently higher quality metal, fronts are Grade 8.
MBlac649
Jun 17, 2013 05:51 PM
FosterW
May 11, 2011 11:10 AM
Chaotic94
Nov 9, 2010 11:21 AM
MS69 YENKO/4-SPEED
Jun 22, 2010 05:07 PM
gozzy341
Nov 4, 2007 08:52 PM
