shocks
Old Feb 14, 2013 | 05:10 PM
Patrick Quentin Musick's Avatar
Default shocks
Hey guys i have a 94 camaro v6 the drivers side lower mount for my rear shock is GONE can i replace the bracket (is it bolt on ) or does it have to be cut n welded?
Old Feb 14, 2013 | 06:32 PM
welded, may be a good excuse to pick up a disk brake rearend. so how the heck did that get gone?
Old Feb 14, 2013 | 06:38 PM
might be a stupid question but are the mounts welded to the rear
this is my first time with suspension
Last edited by Patrick Quentin Musick; Feb 14, 2013 at 06:38 PM. Reason: misspelling
Old Feb 14, 2013 | 06:50 PM
are you talking about the bolt or the mount, mount is welded to the rearend and shock bolts to it.
Old Feb 14, 2013 | 07:28 PM
okay last question where are the jack points on the car?
Old Feb 14, 2013 | 08:44 PM
there are plastic pads just behind the front wheels for front. center of differential or on the axle for rear, there is also spots on the subframe that can be used.
Old Feb 15, 2013 | 09:59 PM
yeah the mount looks rotted so it will have to be replaced any idea on how to make the plate or hopefully where i can order it?
Old Feb 16, 2013 | 09:28 AM
got pic? i cant find anything on shock mounts. may have to weld repair
Old Feb 17, 2013 | 07:20 AM
fbodyrs96's Avatar
Those plastic pads are not Jack points, even says do not Jack here.the frame rail right behind it is though, also the k member,http://www.installuniversity.com/ins...ift_points.htm
Old Feb 17, 2013 | 08:19 AM
on the side of the plastic block it says, don't jack here. that means the metal rocker in front of the block. if you place lift pads or a jack on the metal you will bend the metal flange that the fender bolts to and the bottom of the fender pops out. if you use the plastic block you will not damage anything
