pulling my hair out!
Old Aug 10, 2012 | 06:35 PM
|m()d's Avatar
Default pulling my hair out!
well I have a steering wheel shake that is driving me crazy. Anything above 50 gives a good steering wheel shake... but car drives straight and does not pull i can let go of steering wheel and she goes straight but shakes back and forth like an 8th of an inch! Parts replaced so far..rims and tires.. inner and outer tie rods, wheel bearings, upper and lower ball joints. and i used moog parts had tires balanced and 2 allignments now. If you sit in passanger seat you can feel a "hop". tires are new 275 40 17 with new ekei rims.
Ive owned car for aprox 3 months previous owner said he hit curb. rim was bent on front and rear left (drivers side). car was dropped 2 inch but i put original springs back in.
Any and all ideas would be great. thanks in advance
Old Aug 10, 2012 | 08:28 PM
jkeaton's Avatar
So your driving on bent rims and wondering why you have a vibration?
Old Aug 10, 2012 | 08:34 PM
|m()d's Avatar
ok..... new tires and rims that was first thing i changed.
Old Aug 11, 2012 | 12:22 AM
May want to look at the rear end for a bent axle flange.
Old Aug 11, 2012 | 01:59 AM
Lumbee2ss's Avatar
Check the harmonica balancer
Old Aug 11, 2012 | 02:34 AM
MKCoconuts's Avatar
Sounds like a tires mis-balanced. Most common problem with a car that only shakes at certain speeds. Have them rechecked some where other than where you last had them done or take it back to the original place and tell them there is still a problem. Either or will work. The weights they put on the wheels can be thrown off if not put on correctly and will cause a car to vibrate. Only other thing is a tire with a broken belt inside of it.
Old Aug 11, 2012 | 08:12 AM
When the front end was being worked on and aligned, did they check to see if your rack & pinion has any slop? The gears in your rack could be badly worn. With the wheels off the ground, grab a tire at 3 and 9 o'clock and try to rock it. With what's already been replaced, you shouldn't have any slop. Look for in and out movement at the tie rods while doing that. If you have some, the rack is shot.
Old Aug 11, 2012 | 10:18 AM
Yep, got to keep the harmonica balanced, you don't want it to be louder than the guitars. lol
Old Aug 11, 2012 | 10:32 AM
|m()d's Avatar
made an apt heading there soon let ya know what they have to say.
Old Aug 11, 2012 | 11:48 AM
Accordion to my calculations, that should do the trick!
