lowering ?'s
#21
None of us know every thing and never will and no one educated on this forum will ever make fun of someone for asking a question because they didn't know.
15 year old parts? Try having 19 year old all original suspension pieces
#22
Floride, sorry to have offended you. I meant you no harm. You def took what I said out of context. I don't think Im smarter than you. I just meant that not everyone here is an expert. Also, that in order to follow what people are saying, it would help to get an idea about what type of suspension is on these cars since its not a typical set up. Noone here wants to insult you. We know you are learning. But reading will help you learn for your own personal knowledge. This way, you'll understand the answers people give. Your correct, asking is a great way to learn. But this isn't a school where every answer is correct. Lots of times, its just opinions. You don't always know how knowledgeable the person your asking is. I enjoy discussing issues on this forum, however, some of what I read would make me cringe, if certain people on were under my hood. Again, sorry to have offended you. Good luck with whatever you decide.
#23
Which is why most of us join the forums. I didn't even know what an LT1 was 3 years ago until I got my Camaro. I knew the gen-I SBC and Mopar LA engines and that was it. 98 percent of what I know about vehicles came from learning hands on from my father helping restore our '66 Satellite and from my uncles. The other 2 percent is split between doing research/reading articles and asking questions here.
As for being smarter than me, on this stuff, you likely are. Changing the battery on this car was harder than it should have been. I don't think Chevy did a good job at engineering its placement, but what do I know? It did make me realize however, that I need a better set of tools. Maybe once we finally get to the garage (the likely LAST step in our house remodel), I will get some fancy ****...but I digress.
I look to more educated people on the forum for guidance, but I have seen some advice on here that has made me cringe and I don't even know that much. When that happens, I just say "thanks" and move on.
Again, no harm, no foul. Glad we got that **** outta the way.
#24
Talk about a major thread hijack! Oh well, it looked like the OP was done using it anyway!
Flow, if you understand the principles of geometry, and what changes in the suspension when a car is raised or lowered, and why you need to change some of these parts, then we don't need to beat that dead horse.
As far as installing control arm relo brackets, I'd save that till you're all done and keep a "wait and see" outlook. The need depends on the amount of drop. Again, geometry comes into play here. What can happen is you could get "wheel hop" if you tend to have an itchy right foot when jumping off the line. If your tires are still planting fine, and you're getting no screech-screech-screech and jittery rearend, then I wouldn't worry about installing arm brackets.
#25
#26
"Wheel hop" is a result of axle wrap under hard acceleration. The "washboard effect" from poor roads is something totally different. Hitting bumpy roads and having the car bounce around is not "wheel hop".
#27
Try PA roads.
#28
Been there, done that...both sides of the state. Originally from Youngstown, Ohio, and went to Pittsburgh all the time. I also lived in Philly for a couple of years. LA is just as bad, if not worse-and we don't even have snow!
