Lower bushings on front struts.
Old Dec 27, 2021 | 04:03 AM
Driver50x's Avatar
Default Lower bushings on front struts.
My front struts were worn out, so I replaced them with some from Auto Zone. About 10 months and 3000 miles later, the lowers bushings were completely shot and half missing. So I warranted the struts, changed them again, about 10 months later- same dang problem! So I just ordered a set of AC Delco struts for it, thinking they would be higher quality parts. When I compare the Auto Zone struts to the Delcos they look absolutely identical, same decals, same numbers stamped on them, everything. I starting to wonder if these will really fix the problem.
Have you guys seen a lot of problems with these bushings? Could something else be causing them to fail? Is there anything I can be doing wrong?
Thanks,
Steve
Old Dec 28, 2021 | 12:51 PM
cwilt's Avatar
I replaced my front struts last year. When i removed the old struts i noticed that on the newer struts the lower mount flange was opposite from what was installed. I trired to turn the flange but the bushing was not going to move. Not wanting to compress the struts i brought them to a shop with the old struts to match them up. Not saying this is your issue...but the lower bolts should just slip in with no interference. The struts can come from manufacturer built wrong. Just something to look at.
The lower mount should match the contour of the lower A arm. // not like \ /.
Old Aug 2, 2023 | 01:34 PM
lenarish's Avatar
Bought five years ago on a rockauto delco, after 1000 miles, the bushings were completely destroyed. this is a disgusting quality or a deception of buyers. Although the damper itself works well. My problem is that I am in Russia and there is no possibility of a warranty replacement, very expensive shipment of parts. I had to replace this bushing with a polyurethane one from another car model. Tnper works perfectly, already three years.
cdcrum
Jun 5, 2017 07:35 PM
95z28man
Jan 16, 2016 10:13 AM
ravenger13
Aug 1, 2013 09:28 PM
2Z's
Aug 25, 2012 08:26 PM
Virmagicus
Sep 7, 2011 11:55 PM
