KYB AGX shocks, springs, sway bar thoughts...
Old Jan 27, 2013 | 03:11 PM
  #21
Camarokid94's Avatar
Originally Posted by craby
what size tires on front and rear? sounds about right, will be a tad higher on the driver side like 1/2 inch
245-18 F/ 285-18 R
Oh, so it seems I am at stock height then. Cool, i thought it looked good where it sits now, i could only imagine strano's... :')
Old Jan 27, 2013 | 03:24 PM
  #22
ok whats the tire hight? stock is about 26in. tad less. should be like a 245/40 and 285/35 in18s
Old Jan 27, 2013 | 03:58 PM
  #23
I just checked, yup those numbers are correct.
Old Jul 14, 2013 | 08:05 AM
  #24
Alright, so it took a couple months of intense saving...lol but im getting ready to start on my suspension before i head into anything performance wise. Just ordered a set of BMR springs, and will be buying Founders Performance LCA's & panhard rod next week. Im not too sure if relocation brackets are neccessary but i might just buy it anyway. Ill post pics once I get it all installed!
Old Jul 14, 2013 | 07:52 PM
  #25
libertyforall1776's Avatar
Question
Wow, you got the adjustable rears? I debated about getting them, but figured I would not want to adjust them much, so nixed the adjustables.
How do you like them on full soft? On full soft they are a touch stiffer than the non-adjustable Strano says. Do you put it on full stiff for the strip? Do you find yourself adjusting them any other times?
Curious.
im very happy with strano's hollow front and adjustable rear set.
Old Jul 14, 2013 | 07:56 PM
  #26
Lightbulb
Hope this helps:
4th gen Fbody Spring Rate Database
(Progressive springs are listed with initial and final spring rate)
Manufacturer----------------Model--------------------Front (lbs/in)--------------Rear (lbs/in)------------------------Ride Height Drop (in)
OEM------------------------GM V6 93-97------------------223-----------------------95.4--------------------------------------0.00"
OEM------------------------GM V8 93-97-------------------310-----------------------110---------------------------------------0.00"
OEM------------------------GM V6 98-02-------------------257-----------------------114---------------------------------------0.00"
OEM------------------------GM V8 98-02-------------------292-----------------------114---------------------------------------0.00"
1LE-------------------------GM 1LE-------------------------360------------------------130-180---------------------------------0.00"
Eibach--------------------- V6 Prokit 93-97----------------337------------------------75-135----------------------------------1.00"
Eibach---------------------V8 Prokit 93-97-----------------377-600------------------94-160-----------------------------------1.30"
Eibach-------------------- V6 Prokit 98-02-----------------351------------------------80-137-----------------------------------1.40"
Eibach---------------------V8 Prokit 98-02----------------400-------------------------80-137-----------------------------------1.25"
Eibach---------------------Sportline------------------------360-----------------------80-137--------------------------------1.6" / 1.4"
Hotchkis-------------------Fbody Springs------------------285-525-----------------100-140---------------------------------1.00"
G2-------------------------Super Springs-------------------548-----------------------180-230----------------------------------1.50"
Hyperco Hypercoils-------Fbody Springs-------------------360-580-----------------168-216---------------------------------1.25"
MAC-----------------------Fbody Springs-------------------450-515------------------215-245---------------------------------1.50"
SLP------------------------Level 1 Progressive-------------223-448------------------97-136----------------------------------0.75"
SLP------------------------Level 2 Progressive-------------300-450------------------115-185---------------------------------0.50"
BMR-----------------------Fbody Springs(older spec)------310-550-------------------145-170---------------------------------1.00"
Suspension Techniques--Fbody Springs-------------------428-----------------------161-----------------------------------1.30" / 1.70"
Edelbrock-----------------Fbody Springs--------------------585------------------------120-150--------------------------------1.25"
DMS Springs--------------LS1 98-02----------------------325-630-------------------95-160----------------------------------1.30"
Strano --------------------F body springs------------------550-------------------------150-------------------------------------1.25"
BMR-----------------------performance spring(new spec)-550-------------------------160-------------------------------------1.25"
Vogtland-------------------F body spring-------------------440-542--------------------183-228--------------------------------1.2"
Shock Rate Database
Manufacturer------------ Model/Location-------------------- Bump--------------------------------------------- Rebound
Bilstein ------------------HD Front---------------------------- 159------------------------------------------------ 279
Bilstein -------------------HD Rear----------------------------- 86------------------------------------------------- 174
SLP/Bilstein-------------- Front-------------------------------- 130------------------------------------------------ 397
Originally Posted by Camarokid94
Im just going to save up the coin and buy a set of strano's but right now I am just trying to figure out the stock ride height for a lt1..my z sits at 27 f/28 r...can anyone to me if this is normal or something different? Google has failed me for this information -___-
Old Jul 14, 2013 | 07:58 PM
  #27
Lightbulb
Strano springs are the ones you want -- autocross proven. Cancel your BMR order lol.
Did you ever phone Strano to discuss your goals for the car? If not, I would still recommend doing so!
Step one for you should be to replace those kyb agx shocks with Bilsteins or Koni SA Sports... With lowering springs, you have to go with Konis, IF you want your shocks to last their full life...
Old Jul 14, 2013 | 08:08 PM
  #28
If you are bottoming out, you need to check your bumpstops' integrity and possibly get better shocks -- NOT KYB AGX...
Yes, lowering springs can also improve handling performance, just ask Strano.
Originally Posted by flowride
Craby seems to really like those Strano springs. I think the owner of that company is a tech contributor on another site, too.
I am likely ordering the BMR's. They have rears with a one inch drop on fleabay for $130. Since I've already dropped the front 1.5", I don't want to be overly agressive in back. All that bottoming out on L.A. roads is just AWESOME.
Old Jul 14, 2013 | 08:25 PM
  #29
put the adjuster where sam told me to and it works fine. i think its the fartherest hole out on the end.
Old Jul 14, 2013 | 09:00 PM
  #30
So you never adjust it? Do you goto the strip at all?
