Eibach Sportlines Install
Old Mar 3, 2013 | 06:08 AM
Randy Bilyea's Avatar
Default Eibach Sportlines Install
So, continuing with the upgrades, we started the lowering springs install this weekend.
Here's the new:
Eibach sportlines and QA1 panhard bar.
We got the rears done on Saturday, after much screwing around with the drivers side bolt on the panhard bar, we eventually just cut the head off and drove the bolt through. It was seized in the bushing and we had to use the impact hammer to drive it through.
The rest of the rears was VERY easy. Undo the bottom shock bolt, lower the rear axle, and the springs pulled right out. Install new ones, bolt everything back up and it's done. Except for the links of course, I am picking them up this afternoon.
Rear spring comparison:
Fronts were another story altogether.
After breaking both sway bar links, we undid the upper ball joint, undid the bottom shock bolts, undid the top strut mount bolts, they pulled right out.
Only to find that the top nut on the shock was so badly rusted that it is impossible to get them out of the strut mounts.
So, on Monday, I am getting KYB AGX's for the front, along with new mounts. Yippee.
This will successfully eliminate the rest of my upgrade budget for a long while....wife is getting VERY grumpy...
Old Mar 6, 2013 | 10:21 AM
Well, they are in, and it is LOW....
Before:
After:
Still need to clean it and do a few other minor things, but it looks pretty good I think.
Took it out for a quick rip (still pretty sandy on the roads here) and it was good, not too stiff. I have the shocks set to "2" right now, on a scale of 1-8. I will play around with them a bit once it clears up outside to see what I like best.
Dropped it about 1 3/4" in total, as advertised. I imagine it might settle a bit as I drive it too:
Before:
After:
Before:
After:
Old Mar 6, 2013 | 10:40 AM
Everett#2390's Avatar
I likey - thanks for the pictures.
With the Camaro lowered, seems to fill in the wheel opening better.
Old Mar 29, 2013 | 04:45 PM
Blew through a 1/2 tank of gas today cruising around and all I can say is WOW.
What a difference those shocks and springs made on this thing in the corners.
I can feel the bumps and sways in the road a bit more, but cornering is night and day to what it was on the OEM stuff.
I can't wait to do the sway bars, SFC's and torque arm now....I hope it has the same kind of improvement!
Super happy with this mod!
Old Mar 31, 2013 | 10:23 PM
Socom's Avatar
November 2010 ROTM
October 2011 ROTM
SFCs would have been my first mod with a vert car.
84 z .....
Mar 19, 2014 01:00 PM
maudyZ28
Jul 15, 2010 02:08 AM
1990CamaroRS
Jan 14, 2009 06:09 PM
nazariol
May 25, 2008 01:19 PM
nazariol
May 16, 2008 01:28 PM
