96 camaro rs back wheel PROBLEM
Old Feb 18, 2008 | 01:08 AM
blkgagt94's Avatar
Default 96 camaro rs back wheel PROBLEM
just bought a 96 camaro the kid had put on the subframe connecters an back sway bar iam guessing iam new to camaros. i just put lowering springs on but thats not it cars still on jack stands hasnt touched the ground with the new springs. PROBLEM is i just put on my wheels there 18" rims with 245/45/18 tires. thing is that the driver side back the tire is about the same distance away from the rockers an back bumper as for the pass. side the tire is less then a thumb away from the rocker an bigger gap from back bumper whats the deal here? just the pass. side
Old Feb 18, 2008 | 01:50 AM
blkgagt94's Avatar
Default RE: 96 camaro rs back wheel PROBLEM
just talked to the dude an he said might be the relocation bars since theres diffrent holes he did one side an friend did other so his friend must of did the wrogn hole im check it 2mar
Old Feb 19, 2008 | 05:01 AM
blkgagt94's Avatar
it anit the subframe connecters its somthing else? its only the pass. back side wheel that is like less than a inch from the rocker. what is it ?
Old Feb 25, 2008 | 10:06 AM
1969 SS's Avatar
you don't mention the difference in distance from the driver and passenger sides, you only mention the passenger side?
Old Mar 10, 2008 | 02:16 PM
whammer3024's Avatar
ROTM Winner
may want to look in to control arm relocation brackets. they're a must on a lowered 4th gen
Old Mar 10, 2008 | 05:17 PM
importmd's Avatar
is the lower control arm bent? someone jack the car up on it?
libertyforall1776
Jul 28, 2013 12:39 AM
lightningcruiser
Jan 7, 2012 10:51 PM
Brayan99
Jun 16, 2011 05:50 PM
bitter rod
Oct 5, 2009 04:50 AM
1979RS
Jan 15, 2008 09:37 PM
