1995 suspension
Old Feb 4, 2007 | 06:46 PM
2fast4u's Avatar
Default 1995 suspension
what are the best things to upgrade first in the suspension to get better handeling?
Old Feb 4, 2007 | 09:30 PM
blackz87's Avatar
Default RE: suspension
If you state the yearand model car it might help. Not mind readers on this board.
Old Feb 4, 2007 | 11:59 PM
We actually have a mind reader in the forum, but he took the month off.
Old Feb 5, 2007 | 01:54 PM
2fast4u's Avatar
srry i always forget its a 95 3.4 5speed firebird
Old Feb 5, 2007 | 04:09 PM
blackz87's Avatar
Best suggestions for that car would be new Shocks and a bigger wheel and tire package (17"). Outside of that, unless you have deep pockets that would be it.
Old Feb 5, 2007 | 06:36 PM
Yes and make sure all the suspension parts are in good condition. Tie rods, ball joints, bushings, etc.. If not all the fancy parts won't make much of a difference.
Old Feb 6, 2007 | 01:06 PM
z28child's Avatar
how about on a 78 z28 350 4speed?
Old Mar 7, 2007 | 01:00 PM
Tacos Z's Avatar
Swaybars swaybars swaybars.... That is the best mod to make to your suspension in any car.. Find the thickest ones you can find and youll be scared at the improvement.. I guarantee it.
But I also agree with Z28Pete, make sure all the parts are in good shape otherwise, it will be a sloppy car with no body roll.. Not much better..
Old Mar 12, 2007 | 12:35 AM
1969 SS's Avatar
on your 78
start with checking your suspension for worn components and bushings. if all that is good then tires are next because all the suspension mods in the world aren't gonna help if your tires can't hold
poly bushings will make a world of difference because it will help with suspension deflection
sway bars are nice
if you are going all out, I would save the spings and a high-performance shock (if your stock ones are in good condition) for last. if you do this in stages, you can see what each improvement actually does
this is just my opinion but everybody has their own
Camaroforlife
Feb 12, 2016 05:30 PM
numskull223
Jan 4, 2012 09:21 AM
jpowers
Feb 22, 2010 07:43 PM
pherman
70-81 V8 Tech
Jul 20, 2008 09:28 PM
chadscamaro
May 21, 2004 07:57 PM
