Sofie's Turbo Build
Old Dec 26, 2015 | 09:33 PM
  #41
Well it sound like you are doing it right. It helps if it is a known combo for the tuner. As you know there is a lot that goes into building a turbo system and there is a lot that can go wrong. In a perfect world it would be nice to test the system. Are you adding a extra ring gap to the top ring vs stock?
Old Dec 27, 2015 | 01:11 PM
  #42
microkid's Avatar
March 2011 ROTM
Technical User
we're following the specs and recommendations of the piston manufacturer for the application. they have their ring gap measurements, then +/- charts for applications. they're total seal rings as well
Old Dec 28, 2015 | 08:39 PM
  #43
Is the application take into account the car will have a turbo? Seems like a early failure point on turbo engines is top ring getting too hot seizing and ripping the top land right off piston. Maybe Cheeks can chime in on this?
This will cause slightly more blow by but it should make the engine a little more forgiving if you can some crappy fuel or waste gate sticks for a second or two.
Old Dec 29, 2015 | 08:33 AM
  #44
microkid's Avatar
March 2011 ROTM
Technical User
if i recall correctly, yes. it has 4 sections; street, strip, nitrous, forced induction. also gives bore tolerance to allow for the piston growth. very detailed info to give the machinist
Old Jan 1, 2016 | 07:04 PM
  #45
DarlingReject's Avatar
Prettiest Sixer Around
September 2010 ROTM
Done the cage!
Old Jan 2, 2016 | 03:55 PM
  #46
Socom's Avatar
November 2010 ROTM
October 2011 ROTM
Is that a custom fabbed or pre-fabbed cage? I would've gotten the main hoop as close to the roof as possible so that if it were to collapse it wouldn't have much of a gap until it hit the bar. I'm tall so that could make a difference
Old Jan 2, 2016 | 06:58 PM
  #47
September 2010 ROTM
Pre fabbed. It's S&W. The hoop is against the headliner. I'm not real tall so I should be fine. I don't plan on real racing or anything, just wanted some added safety.
Old Jan 3, 2016 | 07:39 AM
  #48
well isn't it required once you hit 11 second quarter. good goal.
Old Jan 3, 2016 | 08:49 AM
  #49
September 2010 ROTM
Definitely not going fast enough to require anything 10 pt+. Roll bars and roll cages are a real pain in the *** to work around.
Old Jan 3, 2016 | 09:20 AM
  #50
Socom's Avatar
November 2010 ROTM
October 2011 ROTM
Good idea, at least you got swingouts. Being 6' 3" climbing into any caged car without swingouts means I have to bend in weird ways to get in and out lol.
