Sofie's Turbo Build
Old Sep 20, 2016 | 06:46 PM
  #161
must be the wind, looks like one wheel is smoking or is that burnoff
Old Sep 23, 2016 | 04:20 PM
  #162
DarlingReject's Avatar
Prettiest Sixer Around
September 2010 ROTM
This was the last pull. Disappointed with the outcome, but expected there to be an issue with her. The MAF was maxed out and the speed sensor is being goofy, so the torque convertor wasn't staying locked, so the numbers are lower. 400+ at the wheel will be easily attained once that's all figured out. For now she's only 300 whp (roughly 360 at the crank) with 340 torque on 7 pounds of boost. Not much to gloat about.
Brain said she was one if the cleanest ones he's seen. And she was well put together and thought out. Everything was tastefully done and he would totally drive her. So although my numbers disappointed me, I could at least leave with compliments like that from him.
Old Sep 27, 2016 | 07:26 AM
  #163
Cheeks's Avatar
August 2011 ROTM
congrats on getting it on the dyno
I'm wondering why you guys are using a MAF at all? Why not just go speed density and not worry about it? I believe you guys are using hpt, which can turn off any associated CEL's should it be needed
Old Sep 28, 2016 | 05:28 AM
  #164
September 2010 ROTM
Direct quote from Brian,
"Stock pcm. Not a fan of hacking a 1 bar os with a 2 bar sensor which will screw with the calculations for the trans."
Old Oct 15, 2016 | 07:00 AM
  #165
Cheeks's Avatar
August 2011 ROTM
Gotcha
One of the machine shops we use put this up today, don't know if you saw it yet or not
Link for the article:
http://www.superchevy.com/features/camp-0812-2000-chevy-camaro/
Old Oct 19, 2016 | 01:26 PM
  #166
microkid's Avatar
March 2011 ROTM
Technical User
I read that article a while back, I'm assuming she still has the car?
So far the car has been running great. Footbrake stalled the converter, it easily got to 3200 rpm and 3 psi before I decided to just let it do a burnout and make a smoke show. Still trying to fix the delayed 2-3 as well as fine tune tcc lockup in third and fourth. Its commanded to shift at 6000 and 76 mph, but its going to 6400 and 84 mph. I'm just going to fiddle with the tune and see if I can't get it to work. The shift is still crisp, just late. If it works, it works. I don't forsee spending $500 to diag and fix it when a built trans can be purchased for $2000 that has fully upgraded internals. Current plan is to take her to the strip November 5th
Old Oct 22, 2016 | 08:39 PM
  #167
80sz's Avatar
Like! Nice sound
Old Nov 5, 2016 | 07:41 PM
  #168
September 2010 ROTM
Hit the track today for a test and tune with a small group called the Mullet Militia (for 3rd Gen enthusiasts). Didn't get many runs in because we were between some pro stick and super stock classes. But my best pass was a 13.106 @ 106.23 mph in 1/4. Definitely need more seat time, but I was happy. The car has 12s in her no problem. Need to tweak the tune a tiny bit more and throw on some slicks. This is only had 7 pounds of boost, too. The goal is 20 pounds for next year with a re-dyno tune. Here's a video from the last run which was a 13.189.
Old Nov 6, 2016 | 01:30 PM
  #169
very cool. looks and sounds great
Old Nov 10, 2016 | 05:29 AM
  #170
September 2010 ROTM
From Saturday
