Sofie's Official Engine Rebuild Thread!
Old 09-18-2010, 03:23 PM
DarlingReject's Avatar
Prettiest Sixer Around
September 2010 ROTM
Ha thanks. I lightly sanded the struts and painted them with my pink acrylic enamel. I didn't feel like taking them off, so I taped everything off around it. The alternator I just sprayed and kept the connector in the back covered. It's a little on the old side and will probably need replaced in a year or so, so it just got sprayed with the black engine enamel. Didn't bother prepping it or anything. I just kinda wiped some dirt off and that was it.
  #302
Old 09-18-2010, 03:46 PM
Murda99v6's Avatar
Two Cylinders Short of Win
Ahhh ok. Yeah I wanted to paint mine today but didn't feel like taking them off either and considered doing that, but thought I'd find out if any1 else did it like that. Your pink acrylic enamel was sprayed onto the struts correct?
As for the alternator, I've read a few different ways of doing it but didn't know how each method looks when finished. So you didn't cover up the holes where the wire windings are at before you sprayed it?
  #303
Old 09-18-2010, 03:55 PM
September 2010 ROTM
Yeah sorry, it was a spray can. As long as the connector in the back isn't touched, it should be fine. Mine was just sprayed and it works fine. I would try not to spray into anything as much as possible, but it's ok if it gets some paint on it.
  #304
Old 09-18-2010, 03:59 PM
Murda99v6's Avatar
K thanks...sorry for all the questions on your Engine Rebuild Thread. 1 more: Do you know if Krylon Fusion Paint can be used for the hood struts? I don't know if I should just stick to high temp paint like Caliper or Engine Enamel or if I can use the Krylon Fusion with the same results. Its supposedly better for bonding with no prep.
  #305
Old 09-19-2010, 12:16 PM
September 2010 ROTM
You won't need high temp paint. And ALWAYS prep. Taking the time to prep things will always give you better and longer lasting results. No-prep stuff is nothing but BS. That Krylon should be fine to use, I used my acrylic enamel because it was what I used on my intake and valve covers, so to match it, I continued to just use that.
  #306
Old 09-20-2010, 07:04 PM
92typhoon937's Avatar
damn u all did good job with ur car i just read through most of the posts lol
  #307
Old 09-20-2010, 07:41 PM
September 2010 ROTM
Ha thanks.
  #308
Old 09-21-2010, 09:36 PM
hey passedu today in dallastown bout 3:30
i was in dump truck when u drove by
  #309
Old 09-23-2010, 07:03 PM
September 2010 ROTM
Ha I was going to/from my favorite place, Advance Auto.
  #310
Old 09-23-2010, 07:48 PM
do anything with your ps pump yet? +gota get the vote link on this page. lol
Quick Reply: Sofie's Official Engine Rebuild Thread!
