Sofie's Official Engine Rebuild Thread!
#191
Well I'm finally getting around to doing this. I made a list of the stuff we found wrong with Sof and a list of what was replaced and upgraded.
Wrong
1. Loose injector wire
2. Pushed-in pin in coil pack connector
3. Bad oil pan gasket
4. Bad front cover gasket
5. Incorrect lower intake gaskets
6. Very dirty TB
7. Bad cam bearings
8. Marks on cam
9. Marks on crank
10. Mark in cylinder 4
11. Sludge build up and oil crud
12. Cracked head between valves
13. Burnt valve springs
14. Bent AC connector
15. Worn out cam chain
16. Faulty oil sending unit
17. Mismatched valve covers
Replaced/Upgraded
1. All new gaskets
2. GT1 cam
3. Cleaned everything
4. Painted everything
5. New lifters
6. Reman heads
7. Fixed pin in coil pack connector
8. Cleaned out TB and MAF
9. New 21 lb fuel injectors
10. Oil sending unit
11. Timing chain
12. Wire looming
13. Oil pump
14. Painted hood struts
15. Strut tower brace
16. Fixed AC
17. New fuse box labels
18. Piston rings
19. Cleaned block
20. Port matched and polished intake
21. Starter
22. 180* thermostat
23. Ground/polished crank
24. Honed block
I'm sure I forgot a bunch of stuff. I'll add to the lists whenever I remember more stuff. So it was basically a stock rebuild. My intentions in the beginning were to do more machine work to the block, which is why I didn't want to just buy another engine and throw in. But as time went on and Pharro was giving me problems, I opted to just do any parts upgrades I could and just be done with them. But the small things I know will make a difference. Just the block being cleaned and all the parts getting cleaned added a bunch of extra hp over what she was right before the build. Not to mention about 100 lbs of weight reduction. I never realized how bad she really was on the inside. Then I decided on the bigger cam last minute because I can't resist a cammed car and I had saved money on not having more block work done. The cracked head was a surprise, but that's why I budgeted enough for almost anything to go wrong. It took over a month to build because Pharro took their sweet time. If I were to do this again, I'm not sure I would. I would definitely not go to Pharro though, that's for sure. It put a strain on the relationship, but it gave us both a very valuable learning experience. Not only in how these engines are built, but in how we work together. I know 100 times more about my car than I did 2 months ago. I definitely would NOT trade that for anything. That was the point in the beginning though. To learn more about this engine. She's such a mystery as to what happened before I got her. It's in my nature to want to tear it apart and try to figure it out. Even though I wasn't the one doing most of the tearing apart or figuring out. But oh well. I'm hoping when I get her tuned next year I can get a hefty hp jump. Hoping between 250-270 hp. I'm trying to stay realistic. She'll also get a new set of rear gears then as well. This is NOT my race car. So her intentions is not to be the quickest six out there, but a faster, 'fuel efficient' (if I could stay out of the pedal, lol), daily driver that looks and sounds amazing. There's still a LONG list of mods I want to do. But my bank account needs a break for now. My budget for the build was $3k. I spent (in receipts that I could find and total up) $2,948.37. I'm sure there's more misc stuff here and there I missed, but I was on track with the budget. I really only have Case to thank for all his help in the build. I know I wouldn't have been able to do any of it (other than the painting and cleaning parts) without him. I didn't know anything about rebuilding an engine. But now I do. In total I have invested in the car including the build is over $6,500. And that amount will keep on climbing....
After this engine goes in about another 100k miles, I'm thinking of a turbo build for her...but only time will tell.
Wrong
6. Very dirty TB
7. Bad cam bearings
8. Marks on cam
9. Marks on crank
Replaced/Upgraded
1. All new gaskets
2. GT1 cam
5. New lifters
6. Reman heads
11. Timing chain
12. Wire looming
13. Oil pump
16. Fixed AC
18. Piston rings
19. Cleaned block
21. Starter
22. 180* thermostat
24. Honed block
#195
haha, my thoughts exactly as i tore it down. and it ran and sounded great. it out ran my blazer, even when she didnt launch. that was before she added the headers or intake or anything else, and i already had a full exhaust and intake and an experience advantage
#196
I know. I was amazed at everything. But she ran as strong as she could for me. Never left me stranded. She stepped up and took off when I asked her to. I'm still not sure how after finding everything.
