93 Camaro lt1 Build, Craby's
#31
headers and y pipe got here. now i think i have everything for this part of the build. first time in my life i want to get taxes done as fast as i can. lol. back to paper work now. heres a couple pictures.
![Name: headers1.jpg
Size: 55.9 KB](https://camaroforums.com/forum/attachments/93-02-projects-109/36403d1501324914-93-camaro-lt1-build-crabys-headers1.jpg)
![Name: kooksheaders2.jpg
Size: 45.9 KB](https://camaroforums.com/forum/attachments/93-02-projects-109/36404d1501324914-93-camaro-lt1-build-crabys-kooksheaders2.jpg)
#32
cars all set up in the shop to get started, drained the radiator, also had the ac discarged today. ill take some pictures tomorrow.
heres whats in it so far;
Intake
fully ported
enlarged runners
58mm tb opening
58mm bbk throttle body
LT1 LE2 heads
manley 2.00/1.56 6000 series valves
patriot gold extreme springs (155 lbs seat and 400 lbs open)
205 cc intake port
flow about 275/190 CFM
bullet racing cam grind #CLT276/281-12HR
223/230 .565/.565 112 separation
single roller timing chain with gears
aluminum billet oil pump drive housing
comp cam roller rocker arms
1.6 7/16 pro magnum
tpis performance roller lifters
GM performance composition head gaskets
part # 12553160
.028 compressed thickness
gm performance oil pump NAL-12555884
5.5 qt moroso oil pan 20185
arp oil pan studs 234-1901
arp main bearing studs 134-5601
moroso oil pump pickup 24212
rpc valve covers
kooks 1 3/4 x3 headers jethot coated
kooks catted y pipe jethot coated
transmission
700r4 raptor level 3 transmission
raptor drive upgrade
power gear 6 pinion upgrade
5x power raptor lockup converter 2000 stall
msd vented opti
msd blaster coil
8.5 mm msd plug wires
Intake
fully ported
enlarged runners
58mm tb opening
LT1 LE2 heads
205 cc intake port
1.6 7/16 pro magnum
part # 12553160
rpc valve covers
transmission
msd vented opti
msd blaster coil
#35
im curious, does the y-pipe go to the cat or cancel it out. i see you have the cated y pipe. wasnt sure if ya just needed to add some pipe to it or just hook it up to the rest of the exhaust.
#36
well its supposed to match up with the exhaust where the cat did so it does away with it. ill see. the 93 is an unusauall car and is not like any other in many ways so the headers are not a simple bolt on and go. im leaning toward not recomending the emmision kooks for the 93. the egr system is way different so im tryin to piece it together. i think i found a egr pipe that will fit but wont know till i get it. then i gotta figure how to get the air pump hooked to the other fittings. learning more than i want about it. lol
i took the intake off the old motor so the lift would have no way to damge and found the gunk was back. i had cleaned it out pretty good when i changed the intake and it looks the same as it was before. were the heck did it come from.
![Name: oldlt1.jpg
Size: 86.3 KB](https://camaroforums.com/forum/attachments/93-02-projects-109/36228d1501324587-93-camaro-lt1-build-crabys-oldlt1.jpg)
#38
i change the oil every 3k and use penzoil, tried the purple stuff once. the motor was abused when i got it. gaskets are hard as a rock so im assuming its been overheated and by the looks of it, run without changing oil. it looked just like that when i changed the intake about 6 months ago and i cleaned all the lose stuff out. i am surprised that it all came back. busted three exhaust bolts off getting the exhaust off. not sure what im gona do with it. i was thinking stroke it and save for a rainy day. lol
#40
I was going to ask if you ever overheated it, but I figured that's something you wouldn't let happen. That crud looks like it's baked on.
For some reason, I don't think Pennzoil is gonna ask you for an endorsement either!![Wink](https://camaroforums.com/forum/images/smilies/wink.gif)
You gonna learn how to do a rain dance too then?
