93 Camaro Build thread *LOTS OF PICS*
I would say I have about 5-6 grand into the car so far (including the purchase price).
Thank you
I will be updating shortly.
Quick update tonight.
I would like to thank MartineZ28 for his writeup for halo headlights mod. I thought it looked awesome and went ahead and did it
Unlike Martine, I spilced/T'd the wires into the factory harness, so the halos come on when the parking lights are on (stock switch), and the headlights turn on with the stock switch
Cool, what brand headlight housings did you go with?
Did you get some HIDs to go with them? http://ddmtuning.com/Product-Categor...hting/HID-Kits seems like one of the best bets out there, which I went with.
Also, quick update: Motor is being planed and the heads are getting a 5-angle valve job
I can't find them on Pep boys website, but if you go into pep boys you will see them. They are $45 and have a blue halo. I think the lightbulb in the light is 5000k HID. I'm not exactly sure what you are trying to do with the lights, but it seems complicated. You won't need to wire the halos to come on when the high beams are on because they should be spliced into the parking lights.
Yea I know. I want the regular part of the light to work as if they are my factory lights (Low beams and high beams)... And I want the blue ring to work on a aftermarket switch.
Oh ok that would be easy to do. The headlights have their own + and - separate from the halos + and -. So you would just splice the headlights into the factory harness and then run wires from the halos to the switch.
