1998 Z28 Camaro
Old Aug 12, 2013 | 10:40 PM
Sean0308's Avatar
Default 1998 Z28 Camaro
I have just recently had my motor go in my 1998 Z28 Chevy Camaro. One of the valve lifters started ticking and I lost the motor at 170000 miles. Now here comes the real question. Has anyone ever attempted to put an LS2 motor in. I have an LS1 motor right now but I am just curious if anyone has attempted this I know the motor mounts have to be changed the computer has to be flashed and reprogrammed or it may even need to be replaced. I would say the vacuum harness is different and the wire harness would be different. The sensors should be close I would say. But I am not sure. Anybody know. Thanks.
Old Aug 13, 2013 | 12:29 AM
MKCoconuts's Avatar
Curious why you'd want to go to an LS2 instead of rebuilding or replacing your current LS1?
Old Aug 13, 2013 | 08:04 AM
Cheeks's Avatar
August 2011 ROTM
I'll answer yours first, since its easier. More displacement, more power, better stock heads and intake.
for you, the biggest hurdle you're going to face is how to deal with the reluctor wheel. do some searching, there are a bunch of info regarding this swap as it has become more common then you think. Scoggin ****ey and Texas Speed sell conversion kits for this very swap
Racetronix LS1 to LS2 Cam Sensor Retrofit Harness
Racetronix LS1 to LS2 Knock Sensor Retrofit Harness
also, start reading here
LS2 conversion info inside - LS1TECH
Old Aug 13, 2013 | 08:14 AM
Just curious. The LS2 has 55 h.p. over the LS1.
Which one would you spend more time and money on to get that 55 h.p.; modifications to the LS1, or a complete LS2 engine conversion with all the trimmings?
Old Aug 13, 2013 | 08:27 AM
Cheeks's Avatar
August 2011 ROTM
its not necessarily more power now, its more power potential later. There are quite a few 500whp stock block ls2 motors out there, that with the right cam/head/intake combo, you can really get them to scream.
Old Aug 13, 2013 | 09:44 AM
Obviously it all depends on what you start with, and where you want to end up. But yeah, enough is never enough is it....I know some people like that (cough cough). In this guys case, he's needing a replacement engine anyway. But is it worth going through an LS2 swap if you already have a healthy LS1 in there? That was my query for the most part.
Old Aug 13, 2013 | 09:49 AM
greenarrow's Avatar
September 2009 ROTM
It really depends on the end goal of the car right. If you can rebuild the LS1 and get you to where you want to be, that seems like it would be the cost effective route.
Old Aug 13, 2013 | 12:32 PM
Sean0308's Avatar
I was just curious of how much work it would be to put an LS2 motor in. Believe me I have no complaints wit this LS1 motor. But since I have the opportunity now to decide I was curious how much work you would have to put into it.
Old Aug 13, 2013 | 03:08 PM
Cheeks's Avatar
August 2011 ROTM
not that much, but it comes down to pricing and time
Old May 28, 2021 | 08:50 PM
Thomas Bell's Avatar
I just put in a. New LS-3 Iin my 98 Z/28/put the throttle body from the original LS-1 ON THE LS-3/KEPT IT A CABLE DRIVEN THROTTLE BODY SET UP/SAVED OVER A THOUSAND BUCKS/
jamguitarist91
Jan 14, 2010 12:21 PM
racertay
Feb 25, 2008 09:28 PM
camroadrenaline
Jul 4, 2007 02:36 PM
Jgravot
LS Series Tech
May 1, 2007 10:28 PM
