Old Aug 3, 2016 | 03:10 PM
  #791
MKCoconuts's Avatar
Go to the bar and offer $50 for them to do a photo shoot with your car. Never know what could happen.
Old Aug 4, 2016 | 09:59 AM
  #792
95 camaro 406's Avatar
we have lonely threads to go too a bar fly
Old Aug 5, 2016 | 08:38 AM
  #793
WIspartan1026's Avatar
May 2013 ROTM
hokay, so...I swapped in a brand new ICM. Seems to drive fine, though it still doesn't idle very well once it's warm. I haven't opened it up on the highway to see if it fixed the ignition issues at high RPM. However, what I'm running into now is the Service Engine Soon light flashes, but when I scan the module, I don't get any codes reported. I first noticed it last Saturday driving back from Cars and Coffee in Plymouth. I was going down Hines Drive, so I never went over 45mph, and I wasn't beating on it at all. I'm not sure if it's because of the new ICM or not, because I have no idea what's causing a fault because there are no codes. Nothing really feels or sounds any different. Any thoughts?
Old Aug 5, 2016 | 10:01 AM
  #794
means your getting a miss fire, at least the computer is seeing one.
Old Aug 5, 2016 | 10:34 AM
  #795
May 2013 ROTM
wouldn't it throw a misfire code, though?
Old Aug 5, 2016 | 11:34 AM
  #796
has to see the same condition so many times before it sets a code. check egr. is exhaust smelling of gas?
Old Aug 9, 2016 | 09:01 AM
  #797
May 2013 ROTM
There is no EGR. Deleted that a long time ago. Exhaust doesn't smell of gas.
Old Aug 9, 2016 | 11:03 AM
  #798
i wonder if the crank sensor is acting up or maybe the cam sensor,,, you just did the opti right?
Old Aug 9, 2016 | 11:44 AM
  #799
May 2013 ROTM
Yeah, I installed a new Opti when I put everything together. Is it possible the new ICM might have something to do with it? The flashing SES only came up after I swapped that.
Old Aug 9, 2016 | 12:36 PM
  #800
double check connections. maybe take it back and see if they will give you another to try. check part numbers to make sure its the right one, im thinking the 96-97 may have a diffent one.
