Window Power Problems
Old Jun 21, 2014 | 09:53 PM
eric forman's Avatar
Default Window Power Problems
I have a 94 3.4 and I replaced the window motor for the driver's side on it a little over a year ago. Not a whole lot longer after that the window began acting funky. It goes up without a problem whenever I want it to, but it will only go down when the ignition is turned so that the power is on before you turn it over but once the car is running it wont go down at all. It used to go down all the way or most of the way before it would stop (if it didn't make it all the way I would just have to turn it off and put it back into the power mode to get it down all the way). After winter it decided to only go down like an inch at a time. Any help with this issue is MAJORLY appreciated!
Old Jun 23, 2014 | 09:43 AM
77camaroLT
May 27, 2013 10:32 AM
mgg4591
82-92 V8 Tech
Jan 31, 2012 09:00 PM
pooter_07
Dec 31, 2010 11:51 PM
mahosky85
Apr 28, 2009 07:48 PM
chevyrebel
Nov 25, 2006 03:19 PM
