Turn signal don't turn off after turning
Turn signal never turn off after turning, its the same on both sides and was so when I got the car.
Is the Turn Signal Switch known to break? and if so, how hard is it to replace?
https://www.rockauto.com/en/moreinfo...t=4832&jsn=688
Steering wheel will need to come off but does the column need to be disassembled too?
I am in the process of ordering several parts and as I'm in Europe shopping in the US, I try to get all I need in one shipment, at the same time I like to avoid spending money on unneeded parts but don't have the possibility to take these things apart right now, so it comes down to likelihood and that's were I need your input and experience...
Found a good video for the replacement procedure (on a 97)
Not an easy job but not impossible either, requires special tools for getting the steering wheel and lock plate off, and a bit of a hassle to route the harness
And regarding my issue, my guess is broken cancelling cams or loose /missing springs, but still curios in case someone has experience to share on the topic
CamBigCat
Jan 25, 2020 04:33 PM
