Should I install a roll cage before I re do interior?
Old Feb 13, 2007 | 03:33 PM
javione's Avatar
Default Should I install a roll cage before I re do interior?
This will be a 2000 camaro. I want to install a roll cage because of corse I want to drag and drift. I want to install sheetmatal door inserts and cover them with sued. Is that possible? I also am going to put 4 new seats.I dont want to have the ultimate drag or drift car because I still want to drive it to work, but I want it to look good and kick a$$. Would this be a good idea.
Old Feb 13, 2007 | 03:58 PM
shnormo's Avatar
Default RE: Should I install a roll cage before I re do interior?
YES!!! Easiest time to install the roll cage. If you're going with aluminum door pieces, DON'T Sued them. You're defeating the whole purpose of aluminum door pannels.
Old Feb 13, 2007 | 04:28 PM
javione's Avatar
I understand sheet metal door pieces make the car lighter. I figured sued was a light fabric and it would make the car look nice though. But you say no go with the sued then?
Old Feb 13, 2007 | 06:52 PM
shnormo's Avatar
Yes sir.
Old Feb 13, 2007 | 10:51 PM
javione's Avatar
where can I find a place that does aluminum door pieces?
Old Feb 13, 2007 | 11:19 PM
shnormo's Avatar
Look for a fabrication shop. you can buy universal ones from jegs that you have to rivet to the door and cut out your own accessory holes and make an arm rest/ something to close the door.
olred78
Aug 26, 2009 08:00 PM
htruck
Feb 12, 2008 02:31 PM
SMM
Dec 4, 2007 10:24 AM
shnormo
Oct 25, 2006 05:37 PM
orlandovdesign
Sep 10, 2006 04:27 AM
