Rearview Mirror Lights
yes the switches on the doors and hatchback that turn the dome light on. going to have to track the power and try and find where its coming from. a wire shorting to power would do it. not sure if the dome lights are ground switched or hot switched. ill see what i can find. i guess a good first place to start after checking switches is to unplug one switch at a time and see if the lights go out. it could be the wheel switch is failing and will not turn off.
libertyforall1776
10-19-2007 12:50 PM
